[GRASS-dev] [Temporal] Access a temporal dataset from another mapset
Laurent C. lrntct at gmail.com
Tue Aug 9 08:13:20 PDT 2016
2016-08-08 10:24 GMT-05:00 Veronica Andreo <veroandreo at gmail.com>:
> Hello Laurent,
> 2016-08-08 12:13 GMT-03:00 Laurent C. <lrntct at gmail.com>:
>> Hello Veronica,
>> Thanks for your answer. Here is my version, under Ubuntu 16.4:
>> $ g.version -b
>> GRASS 7.0.4 (2016)
> grass 7.0.4 should be fine, the change was introduced last year...
>> According to g.mapset -l, the mapsets are in the search path.
> g.mapset -l
> will only list available mapsets, but that does not mean they are accesible
>> If I
>> make the mapset current, I can access the STRDS in that mapset, but
>> not from another mapset. I have one temporal DB for each mapset.
>> Below are the commands:
>> $ g.mapset -p
>> hull
> here you are just printing the current mapset
>> $ g.mapset -l
>> PERMANENT hull_rain hull
> and here listing the available mapsets
> You need to do:
> g.mapsets -p mapset=hull_rain,PERMANENT operation=add
> to indeed add the mapset to the search path and make it accessible from
> other mapset
Ok, I did not see it was g.mapsetS, I did not know this command.
It works now. Thanks a lot Veronica!
And sorry for the noise on dev list.
Regards,
Laurent
