[GRASS-dev] [GRASS GIS] #2055: r.in.gdal lacks flag "-r Limit import to the current region"
trac at osgeo.org
Fri Aug 19 00:55:52 PDT 2016
Reporter: neteler | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.in.gdal, r.import
CPU: Unspecified | Platform: Unspecified
Comment (by neteler):
Replying to [comment:1 mmetz]:
> Replying to [ticket:2055 neteler]:
> > While v.in.ogr offers "-r Limit import to the current region"
> > the module r.in.gdal does not.
> v.in.ogr -r imports all features that overlap with the current region.
The result might thus have extents extending beyond the current region,
which makes sense.
> Translated to raster import, I see a disadvantage when limiting the
import to the current region: for a given project, raw data are commonly
coming from different sources with different extents and resolution. You
would then need to use one of the r.resamp.* modules to resampling raw
data to the current region, and r.resamp.* modules typically extend the
current region by the margin required for resampling (if not nn). Limiting
the import to the current region followed by resampling would thus eat
away rows and columns at the region's borders.
The solution would be "lazy cutting", that is not cutting sharp to the
boundary but allow for a small "extra". Essentially, like v.in.ogr
behaves. Resampling is definitely undesired since we usually import as-is
in r.in.gdal.
Lines to look at:
https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.in.gdal/main.c#L359
Ticket URL: <https://trac.osgeo.org/grass/ticket/2055#comment:13>
