[GRASS-dev] g.search.module: shell style output
Vaclav Petras
wenzeslaus at gmail.com
Sun Aug 21 19:39:19 PDT 2016
On Fri, Aug 19, 2016 at 2:15 AM, Jachym Cepicky <jachym.cepicky at gmail.com>
wrote:
> Hi,
> no special reason for not listing the module description too, just did not
> came to my mind
Thanks. Good to know.
> Just do it [1]
While using the modified version, I actually realized that "shell script
style" usually produces key-value pairs which can which can be evaluated by
shell's eval or grass.script.parse_command. Not all modules comply with
this, e.g. `g.extension -g` produces multiple key-values with same keys and
order matters, so this must be parsed in a special way. The result is
actually exactly the information g.search.modules is producing:
$ g.extension -g
name=v.habitat.dem
description=Calculates DEM derived characteristics of habitats.
keywords=vector,raster,terrain,statistics,sun,zonal statistics
name=v.in.gbif
description=importing of GBIF species distribution data
keywords=vector,geometry
`g.extension -l` produces list of modules in the same way as currently
`g.search.modules -g` produces:
$ g.extension -l
v.habitat.dem
v.in.gbif
As a result, I don't know what to do with -g, at this point I would just
replace the letter by -n (names only) or -s (short output with names only)
and add -t for table output (that's in the attached patch). -g can go to
renamed options for compatibility reasons for now.
For the future, we should try to keep in mind that g.extension and
g.search.module should have unified interfaces and/or outputs. And more
generally, we should define what -g "shell script style" means.
> J
> [1] https://www.youtube.com/watch?v=ZXsQAXx_ao0
> čt 18. 8. 2016 v 20:32 odesílatel Vaclav Petras <wenzeslaus at gmail.com>
> napsal:
>> Hi Jachym,
>> the g.search.module -g flag (shell style output) outputs just names. Do
>> you have a particular reason for it? My use case is something like that:
>> g.search.modules keyword="support" -g | sed -e "s/|[^|]*$//g" | sed -e
>> "s/|/\t/g"
>> with the following desired output (name + keywords, description removed
>> by sed):
>> g.version general,support,citing,copyright,version,license
>> t.support temporal,metadata,time
>> r.support raster,metadata
>> r.support.stats raster,statistics
>> r.out.gdal raster,export
>> v.out.ogr vector,export,OGR
>> r3.support raster3d,metadata,voxel
>> g.findetc general,map management,scripts
>> v.external vector,import,external,OGR,PostGIS
>> g.message general,support,scripts
>> g.tempfile general,support,scripts
>> v.support vector,metadata
>> r.external raster,import,external
>> I can actually see that outputting just module names can be advantageous
>> in some cases. But I want to get something like, so I can throw sed and
>> grep on it:
>> v.support|vector,metadata|Updates vector map metadata.
>> If we permit change of the interface, I think -g could do the output
>> above. This would make the -g output more like the others: same information
>> as by default and with -j, so we can even consider it fixing a bug.
>> The current output with -g can be generated with some other flag. -n* for
>> "names only" perhaps?
>> Best,
>> Vaclav
>> * https://lists.osgeo.org/pipermail/grass-dev/2016-August/081556.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160821/ee2413ff/attachment-0001.html>
Index: g.search.modules.py
--- g.search.modules.py (revision 69155)
+++ g.search.modules.py (working copy)
@@ -52,11 +52,16 @@
#% guisection: Output
#%end
#%flag
-#% key: g
-#% description: Shell script format
+#% key: t
+#% description: Tabular format (pipe as a field separator)
#%end
#%flag
+#% key: s
+#% description: Print only name
+#% guisection: Output
+#%end
+#%flag
#% key: j
#% description: JSON format
@@ -83,8 +88,10 @@
manpages = flags['m']
exact_keywords = flags['k']
out_format = None
- if flags['g']:
- out_format = 'shell'
+ if flags['t']:
+ out_format = 'table'
+ elif flags['s']:
+ out_format = 'name'
elif flags['j']:
out_format = 'json'
else:
@@ -120,14 +127,17 @@
if not out_format:
_print_results(data)
- elif out_format == 'shell':
- _print_results_shell(data)
+ elif out_format == 'table':
+ _print_results_table(data)
+ elif out_format == 'name':
+ _print_results_name(data)
elif out_format == 'json':
_print_results_json(data)
-def _print_results_shell(data):
+def _print_results_name(data):
"""Print just the name attribute"""
for item in data:
@@ -134,6 +144,18 @@
print(item['name'])
+def _print_results_table(data):
+ """Print in shell script style"""
+ separator = '|'
+ for item in data:
+ # replace potential line endings just to be sure we keep the format
+ description = item['attributes']['description'].replace(
+ os.linesep, " ").replace("\n", " ")
+ print(separator.join((item['name'],
+ item['attributes']['keywords'], description)))
def _print_results_json(data):
"""Print JSON output"""
