[GRASS-dev] g.search.module: shell style output
Jachym Cepicky
jachym.cepicky at gmail.com
Mon Aug 22 13:43:02 PDT 2016
Vasku,
IIRC, "-g" flag was introduced first time in 2007 for g.region module and
only reason for taking "g" letter was, that "s" for "shell script" was
taken (or some similar reason). AFAIK there was never defined official
GRASS rule for using -g flag for parsable output as well as how the output
should look like - people simple started to adopt it (like usually in
GRASS).
Putting rule to developer guidelines for parsable output as well as
promoting the "-g" flag for all modules would certainly be an option
Jachym
po 22. 8. 2016 v 4:39 odesílatel Vaclav Petras <wenzeslaus at gmail.com>
napsal:
> On Fri, Aug 19, 2016 at 2:15 AM, Jachym Cepicky <jachym.cepicky at gmail.com>
> wrote:
>> Hi,
>> no special reason for not listing the module description too, just did
>> not came to my mind
> Thanks. Good to know.
>> Just do it [1]
> While using the modified version, I actually realized that "shell script
> style" usually produces key-value pairs which can which can be evaluated by
> shell's eval or grass.script.parse_command. Not all modules comply with
> this, e.g. `g.extension -g` produces multiple key-values with same keys and
> order matters, so this must be parsed in a special way. The result is
> actually exactly the information g.search.modules is producing:
> $ g.extension -g
> name=v.habitat.dem
> description=Calculates DEM derived characteristics of habitats.
> keywords=vector,raster,terrain,statistics,sun,zonal statistics
> name=v.in.gbif
> description=importing of GBIF species distribution data
> keywords=vector,geometry
> `g.extension -l` produces list of modules in the same way as currently
> `g.search.modules -g` produces:
> $ g.extension -l
> v.habitat.dem
> v.in.gbif
> As a result, I don't know what to do with -g, at this point I would just
> replace the letter by -n (names only) or -s (short output with names only)
> and add -t for table output (that's in the attached patch). -g can go to
> renamed options for compatibility reasons for now.
> For the future, we should try to keep in mind that g.extension and
> g.search.module should have unified interfaces and/or outputs. And more
> generally, we should define what -g "shell script style" means.
>> J
>> [1] https://www.youtube.com/watch?v=ZXsQAXx_ao0
>> čt 18. 8. 2016 v 20:32 odesílatel Vaclav Petras <wenzeslaus at gmail.com>
>> napsal:
>>> Hi Jachym,
>>> the g.search.module -g flag (shell style output) outputs just names. Do
>>> you have a particular reason for it? My use case is something like that:
>>> g.search.modules keyword="support" -g | sed -e "s/|[^|]*$//g" | sed -e
>>> "s/|/\t/g"
>>> with the following desired output (name + keywords, description removed
>>> by sed):
>>> g.version general,support,citing,copyright,version,license
>>> t.support temporal,metadata,time
>>> r.support raster,metadata
>>> r.support.stats raster,statistics
>>> r.out.gdal raster,export
>>> v.out.ogr vector,export,OGR
>>> r3.support raster3d,metadata,voxel
>>> g.findetc general,map management,scripts
>>> v.external vector,import,external,OGR,PostGIS
>>> g.message general,support,scripts
>>> g.tempfile general,support,scripts
>>> v.support vector,metadata
>>> r.external raster,import,external
>>> I can actually see that outputting just module names can be advantageous
>>> in some cases. But I want to get something like, so I can throw sed and
>>> grep on it:
>>> v.support|vector,metadata|Updates vector map metadata.
>>> If we permit change of the interface, I think -g could do the output
>>> above. This would make the -g output more like the others: same information
>>> as by default and with -j, so we can even consider it fixing a bug.
>>> The current output with -g can be generated with some other flag. -n*
>>> for "names only" perhaps?
>>> Best,
>>> Vaclav
>>> * https://lists.osgeo.org/pipermail/grass-dev/2016-August/081556.html
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160822/3cb18baf/attachment.html>
