[GRASS-dev] grass-dev Digest, Vol 126, Issue 73
Juan Lorenzo gllore at lsu.edu
Tue Aug 23 08:19:04 PDT 2016
I am sorry to say I will be out of town Sept 1-11
Juan
On 8/23/2016 9:43 AM, grass-dev-request at lists.osgeo.org wrote:
> Send grass-dev mailing list submissions to
> 	grass-dev at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/grass-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	grass-dev-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-dev digest..."
> Today's Topics:
>     1. Re: [GRASS GIS] #2452: v.surf.rst option devi Windows	problem
>        (GRASS GIS)
>     2. Re: Rendering of vector layers can be slow (Vaclav Petras)
>     3. Re: [GRASS GIS] #2234: wxGUI d.mon and g.gui monitor
>        rendering is slow (GRASS GIS)
>     4. Re: [GRASS GIS] #2117: GRASS 7: NVIZ: Transparency error for
>        constant surface in (GRASS GIS)
>     5. Re: [GRASS GIS] #2114: m.nviz.image does not work on	Windows
>        (GRASS GIS)
>     6. Re: [GRASS GIS] #2236: REQUIREMENTS file not clear about
>        compilation and priority (GRASS GIS)
>     7. Re: [GRASS GIS] #386: Thematic grouping of grass modules in
>        the command line (GRASS GIS)
>     8. Re: [GRASS GIS] #1203: explain command mapping to wxGUI	menus
>        (GRASS GIS)
>     9. Re: [GRASS GIS] #645: link documentation to new GUI
>        developments (GRASS GIS)
>    10. Re: [GRASS GIS] #1494: v.in.ogr key flag does not change
>        category values and you loose connection between features and
>        attributes (GRASS GIS)
> Message: 1
> Date: Tue, 23 Aug 2016 13:59:34 -0000
> From: "GRASS GIS" <trac at osgeo.org>
> Subject: Re: [GRASS-dev] [GRASS GIS] #2452: v.surf.rst option devi
> 	Windows	problem
> Message-ID: <058.7db8c3796d75d23235e1ad274dd933b4 at osgeo.org>
> Content-Type: text/plain; charset="utf-8"
>    Reporter:  annakrat     |      Owner:  grass-dev@…
>        Type:  defect       |     Status:  closed
>    Priority:  normal       |  Milestone:  7.0.5
>   Component:  Vector       |    Version:  svn-releasebranch70
> Resolution:  fixed        |   Keywords:  v.surf.rst
>         CPU:  Unspecified  |   Platform:  MSWindows 8
> Changes (by annakrat):
>   * status:  new => closed
>   * resolution:   => fixed
> Comment:
>   I haven't heard of any problems since.
> Ticket URL: <https://trac.osgeo.org/grass/ticket/2452#comment:9>
> GRASS GIS <https://grass.osgeo.org>
> Message: 2
> Date: Tue, 23 Aug 2016 10:02:25 -0400
> From: Vaclav Petras <wenzeslaus at gmail.com>
> To: "Blumentrath, Stefan" <Stefan.Blumentrath at nina.no>
> Cc: "GRASS developers list (grass-dev at lists.osgeo.org)"
> 	<grass-dev at lists.osgeo.org>
> Subject: Re: [GRASS-dev] Rendering of vector layers can be slow
> Message-ID:
> 	<CABo5uVsbNFysCZrHveB1Va8scoq-0dGUfLuPypMjuOrPaVwoBg at mail.gmail.com>
> On Mon, Aug 8, 2016 at 5:27 AM, Blumentrath, Stefan <
> Stefan.Blumentrath at nina.no> wrote:
>> In this context I am struggling with rendering speed in GRASS 7.0.4. I am
>> working on a relatively powerful server with local data in native GRASS
>> format.
> There were improvements in 7.2, can you please test that and reply also to
> #2234.
> https://trac.osgeo.org/grass/ticket/2234
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160823/f54411eb/attachment-0001.html>
> Message: 3
> Date: Tue, 23 Aug 2016 14:03:00 -0000
> Subject: Re: [GRASS-dev] [GRASS GIS] #2234: wxGUI d.mon and g.gui
> 	monitor rendering is slow
> Message-ID: <060.827f8636e6f380a984bbeb1c7e903ab9 at osgeo.org>
> #2234: wxGUI d.mon and g.gui monitor rendering is slow
>    Reporter:  wenzeslaus   |      Owner:  grass-dev@…
>        Type:  enhancement  |     Status:  new
>    Priority:  minor        |  Milestone:  7.0.5
>   Component:  wxGUI        |    Version:  unspecified
> Resolution:               |   Keywords:  rendering, display
>         CPU:  Unspecified  |   Platform:  All
> Comment (by wenzeslaus):
>   Recent comments from mailing list: [https://lists.osgeo.org/pipermail
>   /grass-dev/2016-August/081432.html GRASS-dev Rendering of vector layers
>   can be slow] with those [https://lists.osgeo.org/pipermail/grass-
>   dev/2016-August/081451.html links]:
>   * https://lists.osgeo.org/pipermail/grass-dev/2006-August/025250.html
>   * https://lists.osgeo.org/pipermail/grass-dev/2006-September/025858.html
>   * https://lists.osgeo.org/pipermail/grass-dev/2012-August/059178.html
>   * https://trac.osgeo.org/grass/ticket/2033
> Ticket URL: <https://trac.osgeo.org/grass/ticket/2234#comment:3>
> Message: 4
> Date: Tue, 23 Aug 2016 14:06:01 -0000
> Subject: Re: [GRASS-dev] [GRASS GIS] #2117: GRASS 7: NVIZ:
> 	Transparency error for constant surface in
> Message-ID: <058.59bbea4b86c7fb3ad2efa3ad104ac211 at osgeo.org>
> #2117: GRASS 7: NVIZ: Transparency error for constant surface in
>    Reporter:  richardc  |      Owner:  grass-dev@…
>        Type:  defect    |     Status:  reopened
>    Priority:  normal    |  Milestone:  7.3.0
>   Component:  wxGUI     |    Version:  svn-trunk
> Resolution:            |   Keywords:  NVIZ
>         CPU:  x86-32    |   Platform:  Linux
>   * status:  closed => reopened
>   * resolution:  worksforme =>
>   * milestone:  7.0.5 => 7.3.0
> Comment:
>   Still valid
> Ticket URL: <https://trac.osgeo.org/grass/ticket/2117#comment:4>
> Message: 5
> Date: Tue, 23 Aug 2016 14:06:31 -0000
> Subject: Re: [GRASS-dev] [GRASS GIS] #2114: m.nviz.image does not work
> 	on	Windows
> Message-ID: <058.7d6b0fa99649caf6643db72458bf9353 at osgeo.org>
>        Type:  defect       |     Status:  new
>   Component:  LibOpenGL    |    Version:  svn-trunk
> Resolution:               |   Keywords:  m.nviz.image
>         CPU:  Unspecified  |   Platform:  MSWindows 7
> Comment:
>   Replying to [comment:5 martinl]:
>   > Still an issue?
>   Yes.
> Ticket URL: <https://trac.osgeo.org/grass/ticket/2114#comment:6>
> Message: 6
> Date: Tue, 23 Aug 2016 14:16:36 -0000
> Subject: Re: [GRASS-dev] [GRASS GIS] #2236: REQUIREMENTS file not
> 	clear about compilation and priority
> Message-ID: <060.7c92bb0f32c8a08d6e4a2029b9001db2 at osgeo.org>
> #2236: REQUIREMENTS file not clear about compilation and priority
>        Type:  task        |     Status:  new
>    Priority:  trivial     |  Milestone:  7.0.5
>   Component:  Docs        |    Version:  svn-trunk
> Resolution:              |   Keywords:  compilation, requirements,
>         CPU:              |  dependencies
>    Unspecified            |   Platform:  Unspecified
>   There was several improvements in last two years including Python. An
>   overall review won't harm I guess.
>   https://trac.osgeo.org/grass/log/grass/trunk/REQUIREMENTS.html
>   R is still strange. There is no such thing as R Statistics. We also might
>   need a category Recommended (in scale Dependency - Optional - Recommended)
>   because now R at the same level with C++ which is needed e.g. for
>   r.viewshed.
> Ticket URL: <https://trac.osgeo.org/grass/ticket/2236#comment:6>
> Message: 7
> Date: Tue, 23 Aug 2016 14:28:43 -0000
> Subject: Re: [GRASS-dev] [GRASS GIS] #386: Thematic grouping of grass
> 	modules in the command line
> Message-ID: <055.0e712f56f4eacd6fb51118e0b17d7264 at osgeo.org>
> #386: Thematic grouping of grass modules in the command line
>    Reporter:  nikos        |      Owner:  grass-dev@…
>        Type:  enhancement  |     Status:  closed
> Resolution:  worksforme   |   Keywords:  grouping grass modules
>         CPU:  Unspecified  |   Platform:  Unspecified
>   I don't know what ''worksforme'' refers to here but this was actually
>   fixed for 7.2, not exactly in the originally suggested way but perhaps in
>   a better one, see G72:g.search.modules (and also comment:5:ticket:343).
>   > g.search.modules "landscape"
>   g.gui.rlisetup
>       keywords: general,GUI,raster,landscape structure analysis
>       description: Configuration tool for r.li modules.
>   r.li.cwed
>       keywords: raster,landscape structure analysis,patch index
>       description: Calculates contrast weighted edge density index on a
>   raster
>                    map
>   r.li.dominance
>       keywords: raster,landscape structure analysis,diversity index
>       description: Calculates dominance's diversity index on a raster map
>   The attached CSV can be used to review the existing keywords for modules.
> Ticket URL: <https://trac.osgeo.org/grass/ticket/386#comment:21>
> Message: 8
> Date: Tue, 23 Aug 2016 14:31:04 -0000
> Subject: Re: [GRASS-dev] [GRASS GIS] #1203: explain command mapping to
> 	wxGUI	menus
> Message-ID: <056.04e171ad59be30487ecf540cf28a4807 at osgeo.org>
>    Reporter:  timmie       |      Owner:  grass-dev@…
>    Priority:  normal       |  Milestone:  7.2.0
>   Component:  Docs         |    Version:  unspecified
> Resolution:  duplicate    |   Keywords:  module synopsis, toolboxes
> Changes (by wenzeslaus):
>   * resolution:   => duplicate
> Comment:
>   Closing as duplicated of #645. Please follow up there with wishes for the
>   desired solution.
> Ticket URL: <https://trac.osgeo.org/grass/ticket/1203#comment:15>
> Message: 9
> Date: Tue, 23 Aug 2016 14:31:40 -0000
> Subject: Re: [GRASS-dev] [GRASS GIS] #645: link documentation to new
> 	GUI	developments
> Message-ID: <056.062cf050755b5b294ec3cc3b7b595138 at osgeo.org>
> #645: link documentation to new GUI developments
>    Priority:  minor        |  Milestone:  7.3.0
> Resolution:               |   Keywords:  wxGUI, toolboxes, menu
>         CPU:  All          |   Platform:  All
> Ticket URL: <http://trac.osgeo.org/grass/ticket/645#comment:17>
> Message: 10
> Date: Tue, 23 Aug 2016 14:43:31 -0000
> Subject: Re: [GRASS-dev] [GRASS GIS] #1494: v.in.ogr key flag does not
> 	change category values and you loose connection between features and
> 	attributes
> Message-ID: <058.7af367827184ce0b7c26950ccd1c4cbc at osgeo.org>
> #1494: v.in.ogr key flag does not change category values and you loose connection
> between features and attributes
>    Reporter:  mlennert     |      Owner:  grass-dev@…
>    Priority:  major        |  Milestone:  7.0.5
>   Component:  Vector       |    Version:  svn-trunk
> Resolution:               |   Keywords:  v.in.ogr
> Comment (by martinl):
>   In [changeset:"69241" 69241]:
>   #!CommitTicketReference repository="" revision="69241"
>   between features and attributes (see #1494)
> Ticket URL: </ticket/1494#comment:5>
> Subject: Digest Footer
> End of grass-dev Digest, Vol 126, Issue 73
####### LSU Research - The Constant Pursuit of Discovery
    Juan M. Lorenzo
    Associate Professor
    Dept. Geology and Geophysics
    Adjunct Faculty in Dept. Petroleum Engineering
    Howe-Russell-Kniffen Building Room 215
    Corner South Campus/Tower Drives
    Louisiana State University
    Baton Rouge, LA 70803-4101
    Tel.:                    (225) 578-4249
    Fax:                     (225) 578-2302
    Seismic Shop:            (225) 578-3424
    Harrison Subsurface Lab: (225) 578-4816
    e-mail: gllore at lsu.edu
    URL: http://www.geol.lsu.edu/jlorenzo
