[GRASS-dev] t.register ruins end timestamps
Sören Gebbert
soerengebbert at googlemail.com
Thu Dec 1 00:14:56 PST 2016
You time stamp is a time instance with no duration, hence its not an
interval. Introduce a interval of one second and it should work as expected.
Best regards
Soeren
2016-12-01 9:08 GMT+01:00 Martin Landa <landa.martin at gmail.com>:
> Hi,
> I have raster maps with timestamp defined as eg.
> $ r.timestamp clip_LT51910262011267KIS01_B1
> 24 Sep 2011 09:39:44 / 24 Sep 2011 09:39:44
> After registration to spatial-temporal dataset:
> $ t.register inp=test maps=clip_LT51910262011267KIS01_B
> the timestamp is changed to
> The end time is removed:
> $ t.rast.list test
> clip_LT51910262011267KIS01_B1|pisek_tabor|2011-09-24 09:39:44|None
> Or I am doing something wrong? Thanks, Ma
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161201/917396c3/attachment.html>
