[GRASS-dev] t.register ruins end timestamps
Martin Landa
landa.martin at gmail.com
Thu Dec 1 00:19:18 PST 2016
2016-12-01 9:14 GMT+01:00 Sören Gebbert <soerengebbert at googlemail.com>:
> You time stamp is a time instance with no duration, hence its not an
see r.timestamp, than what means syntax datetime1/datetime2?
> interval. Introduce a interval of one second and it should work as expected.
Do you mean:
$ t.register inp=test maps=clip_LT51910262011267KIS01_B1 --o inc='1 seconds'
ERROR: The increment option requires the start option
? Why start option needs to be given? There is timestamp which defines
start, right? Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
