[GRASS-dev] how to reproject a raster map with absolute numbers without losing data
Moritz Lennert mlennert at club.worldonline.be
Fri Dec 2 02:54:13 PST 2016
On 01/12/16 15:13, Markus Metz wrote:
> On Thu, Dec 1, 2016 at 12:01 PM, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
>> On 30/11/16 09:40, Paulo van Breugel wrote:
>>>> On Tue, Nov 29, 2016 at 5:44 PM, Moritz Lennert
>>>> > An area() function in r.mapcalc would be nice...
>>> |r.mapcalc "rcs = (sin(y()+$nsres/2) - sin(y()-$nsres/2)) * ($ewres *
>>> $PI/180) * float($a)^2";|
>> I tested this approach as well. I.e.
>> area = above formula
>> pop_density = pop / area
>> reproject pop_density
>> pop = pop_density * (ewres*nsres)
>> It is faster than the r.in.xyz <http://r.in.xyz> approach. But it does
> not seem to be as precise.
>> I still lost about 100.000 inhabitants, and more when I smooth more
> (the "loss" increases from nearest neighbor to bilinear to bicubic).
>> In order to avoid precision issues, I tried with both density by m2
> and density by km2, but results are similar.
>> I don't know which part of the error comes from the use of spheroid
> approximation and which part comes from the resampling at reprojection.
>> But I do think that if it is important to maintain exact totals, then
> the r.to.vect - v.proj - v.out.ascii - r.in.xyz <http://r.in.xyz>
> solution seems to be more reliable.
> But with this approach you get spatial artefacts. Assume there are 9
> cell in source with
> 10 10 10
> 10 10 10
> 10 10 10
> they can become in target e.g.
> 10  0 20
> 10  0 20
> 10 10 10
> Total count is maintained, but some target cells might receive no source
> cell whereas other target cells might receive more than one source cell.
Right. I didn't think about that...
Moritz
