[GRASS-dev] how to reproject a raster map with absolute numbers without losing data
Wed Dec 7 22:25:46 PST 2016
Moritz Lennert wrote:
> Yes. Do we have any existing module to calculate area by pixel ? An
> area() function in r.mapcalc would be nice...
I notice that this has been added, but I'm not sure that it's adequate
for this task.
For anything other than lat-lon locations, G_area_of_cell_at_row()
assumes that the area of a cell is constant over the region. That's
true for equal-area projections, and not far off for small scales
(where projection would be almost an affine transformation), but it
could be quite far off at larger scales.
Ideally, r.proj should provide the option to generate maps containing
metadata for a projection: source coordinates, horizontal/vertical
scale factors, area scale factor, rotation angle, skew angle. I.e.
projected coordinates, horizontal/vertical first derivatives, and
information derived from them (maybe also second derivatives, and
derived quantaties such as curvature or radius of curvature, but that
can be quite inaccurate for discrete samples).
IOW, rather than inverse-projecting coordinates and performing a
look-up in a source map, it would inverse-project coordinates and
write the resulting coordinates (or differences).
The main issue is an appropriate choice of delta. Too large a value
means that you're calculating an average over a non-negligible
distance, too small a value means that you lose accuracy due to
subtracting numerically-close values.
