[GRASS-dev] [GRASS GIS] #3213: v.net.iso - Segmentation fault
GRASS GIS trac at osgeo.org
Fri Dec 2 13:49:11 PST 2016
  Reporter:  sebastic     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  closed
  Priority:  major        |  Milestone:  7.2.0
 Component:  LibVector    |    Version:  svn-releasebranch72
Resolution:  fixed        |   Keywords:
       CPU:  Unspecified  |   Platform:  Linux
Comment (by mmetz):
 Replying to [comment:4 sebastic]:
 > Confirmed fixed with the changes from r69951 which have been included as
 a patch in the Debian package.
 Thanks a lot for patching, testing, and publishing the patched Debian
 packages for GRASS 7 so fast!
 Maybe related:
 There seems to be a problem with the interpretation of C language
 standards in Debian testing:
 GRASS 7.0.5 does not compile with -std=c99 because math.h is not included
 (early error in lib/gis), even though math.h conforms to ISO C99 Standard:
 7.12 Mathematics and is included if `__USE_ISOC99` is defined.
 GRASS 7.0.5 does compile with -std=gnu99 (C99 with GNU extensions).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3213#comment:5>
