[GRASS-dev] [GRASS GIS] #3213: v.net.iso - Segmentation fault
GRASS GIS trac at osgeo.org
Sat Dec 3 02:19:52 PST 2016
  Reporter:  sebastic     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  closed
  Priority:  major        |  Milestone:  7.2.0
 Component:  LibVector    |    Version:  svn-releasebranch72
Resolution:  fixed        |   Keywords:
       CPU:  Unspecified  |   Platform:  Linux
Comment (by sebastic):
 Replying to [comment:5 mmetz]:
 > GRASS 7.0.5 does not compile with -std=c99 because math.h is not
 included (early error in lib/gis), even though math.h conforms to ISO C99
 Standard: 7.12 Mathematics and is included if `__USE_ISOC99` is defined.
 > GRASS 7.0.5 does compile with -std=gnu99 (C99 with GNU extensions).
 If GRASS should be compiled with `-std=c99` or `-std=gnu99` the configure
 script in GRASS should set these flags when appropriate.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3213#comment:6>
