[GRASS-dev] GRASS 7.2RC2 blocker
Anna Petrášová kratochanna at gmail.com
Mon Dec 5 11:08:19 PST 2016
On Mon, Dec 5, 2016 at 2:00 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
> I just did this morning. Same problem. No errors in compiling, only in running.
g
Have you checked carefully the gui part of the compilation output?
It's long and the errors are easy to overlook, so I want to make sure.
What files do you have in GRASS-7.2/Contents/MacOS/gui/wxpython/xml ?
Is any of them empty?
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> On Dec 5, 2016, at 11:56 AM, Anna Petrášová <kratochanna at gmail.com> wrote:
>> On Mon, Dec 5, 2016 at 1:52 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>> You mean addons on my local machine or something else?
>> The more I Iook at it, the addons have nothing to do with it. Just try
>> to compile it again, there should be some error. BTW, there is no
>> difference in toolboxes code in trunk and 72.
>> Anna
>>> Michael
>>> C. Michael Barton
>>> www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=1Q8NyOaJG6sOJwStQUePXvYtAPCxEk3JLrhBoC7Ezso&s=xt9rzbPn-6JhkZOF0oRZ4xAytf77ans2GhLJoux9rvw&e= , https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=1Q8NyOaJG6sOJwStQUePXvYtAPCxEk3JLrhBoC7Ezso&s=B0867aqcIFuHWb3i8Cjf90d0V3_4w2hGp_ANetJlZHk&e=
>>>> On Dec 5, 2016, at 11:49 AM, Anna Petrášová <kratochanna at gmail.com> wrote:
>>>> On Mon, Dec 5, 2016 at 1:24 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>>>> Just a reminder.
>>>>> GRASS 7.2RC2 does not run on the Mac.
>>>>> Other versions, include recent 7.3 (I have not tried to compile since
>>>>> September) do work fine. No errors compiling, but I get the error below when
>>>>> I try to run it. Any advice would be helpful.
>>>> I've just compiled it on Mac and it ran just fine. Since the error
>>>> comes from the addon toolboxes, what kind of addons do you have
>>>> installed? I suggest to recompile and check if there are any errors in
>>>> the compilation output.
>>>> Anna
>>>>> Michael
>>>>> C. Michael Barton
>>>>> www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DQIBaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=5qA3mt0eYGlhGT5ZLNbHEc3zjLmnesbRw6j4spKp1oY&s=fG_nZiBNPANgQlxr45MZoW7b4hsq55ZBxX9iuPaePIo&e= , https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DQIBaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=5qA3mt0eYGlhGT5ZLNbHEc3zjLmnesbRw6j4spKp1oY&s=VxZo-g4_6S_iSUp9AKDAJPo7RvtgrHZ2s_mywOGLdsE&e=
>>>>> On Nov 29, 2016, at 1:53 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>>>> Yesterday I compiled GRASS 7.2 RC2 with no errors. Today I tried to test it
>>>>> before posting and got the following error:
>>>>> GRASS 7.2.0RC2 (Global_latlon):~ > Traceback (most recent call last):
>>>>> File "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/wxgui.py",
>>>>> line 158, in <module>
>>>>>   sys.exit(main())
>>>>> line 145, in main
>>>>>   app = GMApp(workspaceFile)
>>>>> line 48, in __init__
>>>>>   wx.App.__init__(self, False)
>>>>> File
>>>>> "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core.py",
>>>>> line 7981, in __init__
>>>>>   self._BootstrapApp()
>>>>> File
>>>>> line 7555, in _BootstrapApp
>>>>>   return _core_.PyApp__BootstrapApp(*args, **kwargs)
>>>>> line 92, in OnInit
>>>>>   workspace=self.workspaceFile)
>>>>> File
>>>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
>>>>> line 129, in __init__
>>>>>   self._menuTreeBuilder = LayerManagerMenuData()
>>>>> File
>>>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/menudata.py",
>>>>> line 42, in __init__
>>>>>   self, filename, expandAddons=expandAddons)
>>>>> File
>>>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/core/menutree.py",
>>>>> line 65, in __init__
>>>>>   xmlTree = etree.parse(filename)
>>>>> File
>>>>> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py",
>>>>> line 1182, in parse
>>>>>   tree.parse(source, parser)
>>>>> File
>>>>> line 657, in parse
>>>>>   self._root = parser.close()
>>>>> File
>>>>> line 1654, in close
>>>>>   self._raiseerror(v)
>>>>> File
>>>>> line 1506, in _raiseerror
>>>>>   raise err
>>>>> xml.etree.ElementTree.ParseError: no element found: line 1, column 0
>>>>> Any idea what this is?
>>>>> Michael
>>>>> C. Michael Barton
