[GRASS-dev] GRASS 7.2RC2 blocker
Michael Barton
Michael.Barton at asu.edu
Mon Dec 5 11:28:14 PST 2016
No errors at all in the compiler log (attached).
The only thing in GRASS-7.2/Contents/MacOS/gui/wxpython/xml/ is
grass-interface.dtd
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Dec 5, 2016, at 12:08 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> On Mon, Dec 5, 2016 at 2:00 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> I just did this morning. Same problem. No errors in compiling, only in running.
> g
> Have you checked carefully the gui part of the compilation output?
> It's long and the errors are easy to overlook, so I want to make sure.
> What files do you have in GRASS-7.2/Contents/MacOS/gui/wxpython/xml ?
> Is any of them empty?
>> Michael
>> C. Michael Barton
>> www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=bBpzPDoS_3Ggj3kC_b9oXWPv1lSAOrSn-2Hm0wfY1jc&s=WOVKug_u69HERAVcBaXjQoUJWB8TmnLwAapaz0X8qug&e= , https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=bBpzPDoS_3Ggj3kC_b9oXWPv1lSAOrSn-2Hm0wfY1jc&s=BurW7at-ZQccpdBaiz13Wq-XTDW5dcwAy5FMysM2hVs&e=
>>> On Dec 5, 2016, at 11:56 AM, Anna Petrášová <kratochanna at gmail.com> wrote:
>>> On Mon, Dec 5, 2016 at 1:52 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>>> You mean addons on my local machine or something else?
>>> The more I Iook at it, the addons have nothing to do with it. Just try
>>> to compile it again, there should be some error. BTW, there is no
>>> difference in toolboxes code in trunk and 72.
>>> Anna
>>>> Michael
>>>> C. Michael Barton
>>>> www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=1Q8NyOaJG6sOJwStQUePXvYtAPCxEk3JLrhBoC7Ezso&s=xt9rzbPn-6JhkZOF0oRZ4xAytf77ans2GhLJoux9rvw&e= , https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DQIFaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=1Q8NyOaJG6sOJwStQUePXvYtAPCxEk3JLrhBoC7Ezso&s=B0867aqcIFuHWb3i8Cjf90d0V3_4w2hGp_ANetJlZHk&e=
>>>>> On Dec 5, 2016, at 11:49 AM, Anna Petrášová <kratochanna at gmail.com> wrote:
>>>>> On Mon, Dec 5, 2016 at 1:24 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>>>>> Just a reminder.
>>>>>> GRASS 7.2RC2 does not run on the Mac.
>>>>>> Other versions, include recent 7.3 (I have not tried to compile since
>>>>>> September) do work fine. No errors compiling, but I get the error below when
>>>>>> I try to run it. Any advice would be helpful.
>>>>> I've just compiled it on Mac and it ran just fine. Since the error
>>>>> comes from the addon toolboxes, what kind of addons do you have
>>>>> installed? I suggest to recompile and check if there are any errors in
>>>>> the compilation output.
>>>>> Anna
>>>>>> Michael
>>>>>> C. Michael Barton
>>>>>> www: https://urldefense.proofpoint.com/v2/url?u=http-3A__www.public.asu.edu_-7Ecmbarton&d=DQIBaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=5qA3mt0eYGlhGT5ZLNbHEc3zjLmnesbRw6j4spKp1oY&s=fG_nZiBNPANgQlxr45MZoW7b4hsq55ZBxX9iuPaePIo&e= , https://urldefense.proofpoint.com/v2/url?u=http-3A__csdc.asu.edu&d=DQIBaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=5qA3mt0eYGlhGT5ZLNbHEc3zjLmnesbRw6j4spKp1oY&s=VxZo-g4_6S_iSUp9AKDAJPo7RvtgrHZ2s_mywOGLdsE&e=
>>>>>> On Nov 29, 2016, at 1:53 PM, Michael Barton <Michael.Barton at asu.edu> wrote:
>>>>>> Yesterday I compiled GRASS 7.2 RC2 with no errors. Today I tried to test it
>>>>>> before posting and got the following error:
>>>>>> GRASS 7.2.0RC2 (Global_latlon):~ > Traceback (most recent call last):
>>>>>> File "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/wxgui.py",
>>>>>> line 158, in <module>
>>>>>> sys.exit(main())
>>>>>> line 145, in main
>>>>>> app = GMApp(workspaceFile)
>>>>>> line 48, in __init__
>>>>>> wx.App.__init__(self, False)
>>>>>> File
>>>>>> "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core.py",
>>>>>> line 7981, in __init__
>>>>>> self._BootstrapApp()
>>>>>> File
>>>>>> line 7555, in _BootstrapApp
>>>>>> return _core_.PyApp__BootstrapApp(*args, **kwargs)
>>>>>> line 92, in OnInit
>>>>>> workspace=self.workspaceFile)
>>>>>> File
>>>>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
>>>>>> line 129, in __init__
>>>>>> self._menuTreeBuilder = LayerManagerMenuData()
>>>>>> File
>>>>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/menudata.py",
>>>>>> line 42, in __init__
>>>>>> self, filename, expandAddons=expandAddons)
>>>>>> File
>>>>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/core/menutree.py",
>>>>>> line 65, in __init__
>>>>>> xmlTree = etree.parse(filename)
>>>>>> File
>>>>>> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py",
>>>>>> line 1182, in parse
>>>>>> tree.parse(source, parser)
>>>>>> File
>>>>>> line 657, in parse
>>>>>> self._root = parser.close()
>>>>>> File
>>>>>> line 1654, in close
>>>>>> self._raiseerror(v)
>>>>>> File
>>>>>> line 1506, in _raiseerror
>>>>>> raise err
>>>>>> xml.etree.ElementTree.ParseError: no element found: line 1, column 0
>>>>>> Any idea what this is?
>>>>>> Michael
>>>>>> C. Michael Barton
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161205/c800ad9a/attachment-0003.html>
Type: application/octet-stream
Desc: error.log
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161205/c800ad9a/attachment-0003.obj>
