[GRASS-dev] t.rast.out.xyz not exporting all cells in the computational region
Moritz Lennert
mlennert at club.worldonline.be
Tue Dec 6 03:31:13 PST 2016
On 06/12/16 10:53, Veronica Andreo wrote:
> Hello Markus
> Thanks for the patch :)
> I applied it in my grass trunk and just tested for a map (146880 cells)
> that contains no data (45757 cells). I get all the pixels with data
> (101123), but nothing for the pixels with no data. It seems to be the
> same as before, no? (It is indeed, the same. I tested with the same map
> in grass72 with no patch)... and if I set the flag -n, I get:
> ERROR: r.out.xyz <http://r.out.xyz>: Sorry, <n> is not a valid flag
> Was that the expected result? or maybe i'm not using it properly...
This sounds like the patch did not apply correctly. It contains the
definition of the -n flag, so you should at least see that when you run
r.out.xyz --h.
Did you run make after applying the patch ?
Moritz
