[GRASS-dev] t.rast.out.xyz not exporting all cells in the computational region
Veronica Andreo
veroandreo at gmail.com
Tue Dec 6 03:38:16 PST 2016
I'm so sorry for the noise!! I forgot to run make :-P Anyway, I just did
and tested again... works as expected!!! Cool!! :))
Thank you, Markus, for the patch and Moritz for the follow up!!
Cheers,
Vero
2016-12-06 12:31 GMT+01:00 Moritz Lennert <mlennert at club.worldonline.be>:
> On 06/12/16 10:53, Veronica Andreo wrote:
>> Hello Markus
>> Thanks for the patch :)
>> I applied it in my grass trunk and just tested for a map (146880 cells)
>> that contains no data (45757 cells). I get all the pixels with data
>> (101123), but nothing for the pixels with no data. It seems to be the
>> same as before, no? (It is indeed, the same. I tested with the same map
>> in grass72 with no patch)... and if I set the flag -n, I get:
>> ERROR: r.out.xyz <http://r.out.xyz>: Sorry, <n> is not a valid flag
>> Was that the expected result? or maybe i'm not using it properly...
> This sounds like the patch did not apply correctly. It contains the
> definition of the -n flag, so you should at least see that when you run
> r.out.xyz --h.
> Did you run make after applying the patch ?
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161206/61c97bfc/attachment.html>
