[GRASS-dev] v.cluster
Markus Metz
markus.metz.giswork at gmail.com
Tue Dec 6 11:59:33 PST 2016
On Tue, Dec 6, 2016 at 8:01 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Tue, Dec 6, 2016 at 7:40 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
> > Hi devs,
> > I am running GRASS 7.3 (R69890), and it seems the module v.cluster is
not
> > available from the menu nor the Modules tab. Typing v.cluster on the
command
> > line or in the Console will run the function fine though.
> > One can still find it on
https://grass.osgeo.org/grass73/manuals/vector.html
> > but it would be nice if it is at least discoverable from the Modules
tab. Or
> > is this a problem with my install?
> no, nobody has put it there yet. What would be a good place? Vector -
> Develop vector map? Or in the main vector menu?
I would suggest the main vector menu because it is a vector analysis tool.
Or change Lidar analysis to Point analysis and add it there. Another
interesting module that could go to a new Point analysis entry is v.nnstat
(after a fix to use not the approximate nearest neighbor but the the real
nearest neighbor) from grass-addons.
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161206/784d3a75/attachment.html>
