[GRASS-dev] v.cluster
Paulo van Breugel
p.vanbreugel at gmail.com
Tue Dec 6 13:07:57 PST 2016
On 06-12-16 20:01, Anna Petrášová wrote:
> On Tue, Dec 6, 2016 at 7:40 AM, Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
>> Hi devs,
>> I am running GRASS 7.3 (R69890), and it seems the module v.cluster is not
>> available from the menu nor the Modules tab. Typing v.cluster on the command
>> line or in the Console will run the function fine though.
>> One can still find it on https://grass.osgeo.org/grass73/manuals/vector.html
>> but it would be nice if it is at least discoverable from the Modules tab. Or
>> is this a problem with my install?
> no, nobody has put it there yet. What would be a good place? Vector -
> Develop vector map? Or in the main vector menu?
Good question, not sure. What about a separate category with modules for
point analysis? This category could include v.kcv and v.perturb (both do
not really generate new points, they are both about modifying existing
point) and perhaps v.distance and v.qcount? In any case, I don't think
'Develop vector map' is the right place, and perhaps good to avoid,
where possible, to have single items in the main menu?
> Anna
>> Cheers,
>> Paulo
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
