[GRASS-dev] GRASS 7.2RC2 problem
Anna Petrášová
kratochanna at gmail.com
Tue Dec 6 15:36:07 PST 2016
There is indeed no error in the log. I can see:
/usr/bin/install -c -m 644 xml/menudata.xml
/Users/cmbarton/grass_source/grass-7.2.0RC2/dist.x86_64-apple-darwin15.6.0/gui/wxpython/xml/menudata.xml
/usr/bin/install -c -m 644 xml/module_tree_menudata.xml
/Users/cmbarton/grass_source/grass-7.2.0RC2/dist.x86_64-apple-darwin15.6.0/gui/wxpython/xml/module_tree_menudata.xml
so the xml files are on the right places. Could you verify that? Are
these files correct? Then when you make install, are these files in
the grass7 app?
Anna
On Tue, Dec 6, 2016 at 5:49 PM, Martin Landa <landa.martin at gmail.com> wrote:
> 2016-12-06 23:45 GMT+01:00 Michael Barton <Michael.Barton at asu.edu>:
>> It is. We don't know what the problem is. I have a guess on this though. It
>> may be a problem with generating the xml code for the addons menu. We had
>> this problem awhile back.
> without full log (run make distclean before configure && make) we
> cannot move from this point (this issue has been reported 7 days ago).
> Thanks, Ma
>> On Nov 29, 2016 10:13 PM, "Michael Barton" <Michael.Barton at asu.edu> wrote:
>>> Yesterday I compiled GRASS 7.2 RC2 with no errors. Today I tried to test
>>> it before posting and got the following error:
>>> GRASS 7.2.0RC2 (Global_latlon):~ > Traceback (most recent call last):
>>> File "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/wxgui.py",
>>> line 158, in <module>
>>> sys.exit(main())
>>> line 145, in main
>>> app = GMApp(workspaceFile)
>>> line 48, in __init__
>>> wx.App.__init__(self, False)
>>> File
>>> "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core.py",
>>> line 7981, in __init__
>>> self._BootstrapApp()
>>> File
>>> line 7555, in _BootstrapApp
>>> return _core_.PyApp__BootstrapApp(*args, **kwargs)
>>> line 92, in OnInit
>>> workspace=self.workspaceFile)
>>> File
>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
>>> line 129, in __init__
>>> self._menuTreeBuilder = LayerManagerMenuData()
>>> File
>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/menudata.py",
>>> line 42, in __init__
>>> self, filename, expandAddons=expandAddons)
>>> File
>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/core/menutree.py",
>>> line 65, in __init__
>>> xmlTree = etree.parse(filename)
>>> File
>>> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py",
>>> line 1182, in parse
>>> tree.parse(source, parser)
>>> File
>>> line 657, in parse
>>> self._root = parser.close()
>>> File
>>> line 1654, in close
>>> self._raiseerror(v)
>>> File
>>> line 1506, in _raiseerror
>>> raise err
>>> xml.etree.ElementTree.ParseError: no element found: line 1, column 0
>>> Any idea what this is?
>> Is this yet a showstopper for the final release?
>> Markus
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
