[GRASS-dev] GRASS 7.2RC2 problem
Michael Barton Michael.Barton at asu.edu
Tue Dec 6 15:45:44 PST 2016
They both have 0 bytes. This is the same problem we had many months back. I had a clunky workaround but it has not been necessary for some time now.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Dec 6, 2016, at 4:36 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> There is indeed no error in the log. I can see:
> /usr/bin/install -c  -m 644 xml/menudata.xml
> /Users/cmbarton/grass_source/grass-7.2.0RC2/dist.x86_64-apple-darwin15.6.0/gui/wxpython/xml/menudata.xml
> /usr/bin/install -c  -m 644 xml/module_tree_menudata.xml
> /Users/cmbarton/grass_source/grass-7.2.0RC2/dist.x86_64-apple-darwin15.6.0/gui/wxpython/xml/module_tree_menudata.xml
> so the xml files are on the right places. Could you verify that? Are
> these files correct? Then when you make install, are these files in
> the grass7 app?
> Anna
> On Tue, Dec 6, 2016 at 5:49 PM, Martin Landa <landa.martin at gmail.com> wrote:
>> 2016-12-06 23:45 GMT+01:00 Michael Barton <Michael.Barton at asu.edu>:
>>> It is. We don't know what the problem is. I have a guess on this though. It
>>> may be a problem with generating the xml code for the addons menu. We had
>>> this problem awhile back.
>> without full log (run make distclean before configure && make) we
>> cannot move from this point (this issue has been reported 7 days ago).
>> Thanks, Ma
>>> On Nov 29, 2016 10:13 PM, "Michael Barton" <Michael.Barton at asu.edu> wrote:
>>>> Yesterday I compiled GRASS 7.2 RC2 with no errors. Today I tried to test
>>>> it before posting and got the following error:
>>>> GRASS 7.2.0RC2 (Global_latlon):~ > Traceback (most recent call last):
>>>>  File "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/wxgui.py",
>>>> line 158, in <module>
>>>>    sys.exit(main())
>>>> line 145, in main
>>>>    app = GMApp(workspaceFile)
>>>> line 48, in __init__
>>>>    wx.App.__init__(self, False)
>>>>  File
>>>> "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core.py",
>>>> line 7981, in __init__
>>>>    self._BootstrapApp()
>>>>  File
>>>> line 7555, in _BootstrapApp
>>>>    return _core_.PyApp__BootstrapApp(*args, **kwargs)
>>>> line 92, in OnInit
>>>>    workspace=self.workspaceFile)
>>>>  File
>>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
>>>> line 129, in __init__
>>>>    self._menuTreeBuilder = LayerManagerMenuData()
>>>>  File
>>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/lmgr/menudata.py",
>>>> line 42, in __init__
>>>>    self, filename, expandAddons=expandAddons)
>>>>  File
>>>> "/Applications/GRASS-7.2.app/Contents/MacOS/gui/wxpython/core/menutree.py",
>>>> line 65, in __init__
>>>>    xmlTree = etree.parse(filename)
>>>>  File
>>>> "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py",
>>>> line 1182, in parse
>>>>    tree.parse(source, parser)
>>>>  File
>>>> line 657, in parse
>>>>    self._root = parser.close()
>>>>  File
>>>> line 1654, in close
>>>>    self._raiseerror(v)
>>>>  File
>>>> line 1506, in _raiseerror
>>>>    raise err
>>>> xml.etree.ElementTree.ParseError: no element found: line 1, column 0
>>>> Any idea what this is?
>>> Is this yet a showstopper for the final release?
>>> Markus
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.osgeo.org_mailman_listinfo_grass-2Ddev&d=DQIBaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=wzegbuCgj3FNHt2EvfUw_NSkDRyjw3UfEGjra7XMnrg&s=A_5YGAlkyo-TX5DrYQbXazvt29qM0wVR54KhVJyCqYY&e=
>> Martin Landa
>> https://urldefense.proofpoint.com/v2/url?u=http-3A__geo.fsv.cvut.cz_gwiki_Landa&d=DQIBaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=wzegbuCgj3FNHt2EvfUw_NSkDRyjw3UfEGjra7XMnrg&s=IW0FiwKY9TZVJMKYQEnTHnyLEgTOUToc6aMN8x1tbGA&e=
>> https://urldefense.proofpoint.com/v2/url?u=http-3A__gismentors.cz_mentors_landa&d=DQIBaQ&c=AGbYxfJbXK67KfXyGqyv2Ejiz41FqQuZFk4A-1IxfAU&r=vxOW6PLS28MPea_dWUwPfRf71TAIziRDuFqWJimQN1I&m=wzegbuCgj3FNHt2EvfUw_NSkDRyjw3UfEGjra7XMnrg&s=RdDtLFNgIXcXjzm3ihlgoJmzAe75YPYatIR81LIHwz0&e=
