[GRASS-dev] Source code link in Addons
Luca Delucchi
lucadeluge at gmail.com
Wed Dec 14 06:39:00 PST 2016
Hi devs,
a power user ask me to implement source code link also in Addons, so I
looked a little bit to the code and it seems it should work already.
During addon compilation Script.make is called, inside this there is
Html.make, this is calling mkhtml.py that contains the code to add
"Source code", so I don't understand why this is not added (with wrong
url) to the HTML file?
Am I missing anything? otherwise I will check a little bit deeper in
the actual code...
ciao
Luca
www.lucadelu.org
