[GRASS-dev] v.select features without category skipped
Vaclav Petras
wenzeslaus at gmail.com
Tue Dec 20 08:14:44 PST 2016
On Tue, Dec 20, 2016 at 10:36 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 20/12/16 16:18, Luca Delucchi wrote:
>> On 20 December 2016 at 16:08, Moritz Lennert
>> <mlennert at club.worldonline.be> wrote:
>>> You can go ahead and commit to trunk, unless someone objects. At least
>>> this
>>> way it gets some testing.
>> are you sure? you should submit it :-/
> I had hoped to put the work on you... ;-)
> But it's done: r70103.
> But we should keep this in mind and observe whether this does not cause
> any issues. Maybe open a ticket ?
Isn't an empty vector map an expected result in this case? What happens
when you do this in GUI (where output is added automatically to Map
Display)? Ticket might be appropriate.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20161220/010d8a3d/attachment-0001.html>
