[GRASS-dev] v.select features without category skipped
Moritz Lennert mlennert at club.worldonline.be
Tue Dec 20 08:57:16 PST 2016
On 20/12/16 17:14, Vaclav Petras wrote:
> On Tue, Dec 20, 2016 at 10:36 AM, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
>     On 20/12/16 16:18, Luca Delucchi wrote:
>         On 20 December 2016 at 16:08, Moritz Lennert
>             You can go ahead and commit to trunk, unless someone
>             objects. At least this
>             way it gets some testing.
>         are you sure? you should submit it :-/
>     I had hoped to put the work on you... ;-)
>     But it's done: r70103.
>     But we should keep this in mind and observe whether this does not
>     cause any issues. Maybe open a ticket ?
> Isn't an empty vector map an expected result in this case? What happens
> when you do this in GUI (where output is added automatically to Map
> Display)? Ticket might be appropriate.
https://trac.osgeo.org/grass/ticket/3226
