[GRASS-dev] [GRASS GIS] #3226: v.select: how to handle situation where no features are found
trac at osgeo.org
Tue Dec 20 08:50:25 PST 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Vector | Version: svn-trunk
Keywords: v.select | CPU: Unspecified
Platform: Unspecified |
Luca described the following scenario [https://lists.osgeo.org/pipermail
/grass-dev/2016-November/083116.html [1]]:
g.region vect=zipcodes -ap
v.mkgrid map=zipcodes_grid box=10000,10000
v.category zipcodes_grid opt=report
Layer/table: 1/zipcodes_grid
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 42 1 42
area 0 0 0
face 0 0 0
kernel 0 0 0
all 42 1 42
v.select ain=zipcodes_grid bin=zipcodes operator=touches
out=zipcodes_grid_final --o
WARNING: Vector map <zipcodes_grid_final> already exists and will be
overwritten
Processing features...
100%
Processing areas...
100%
Writing selected features...
100%
Writing attributes...
WARNING: Array of values to select from column <cat> is empty
WARNING: Unable to copy table for layer 1
DBMI-SQLite driver error:
Unable to create index:
create unique index if not exists zipcodes_grid_final_cat on
zipcodes_grid_final ( cat )
no such table: main.zipcodes_grid_final
WARNING: Unable to create index
WARNING: 97 features from <zipcodes_grid at user1> without category skipped
Building topology for vector map <zipcodes_grid_final at user1>...
Registering primitives...
0 primitives registered
0 vertices registered
Building areas...
100%
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 0
Number of primitives: 0
Number of points: 0
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
v.select complete. 0 features written to output.
I explained that with the operator 'touches', it is normal that no
features were found. However, the error message was awkward. In r70103 a
patch was applied to trunk to count the number of features found and if
that number = 0 then the user is informed and no output map is created.
However, Vaclav remarks:
> Isn't an empty vector map an expected result in this case? What happens
> when you do this in GUI (where output is added automatically to Map
> Display)?
I don't think that a module should output an empty map. But if you think
that it should than we can change the patch.
And yes, the output is automatically added even if it doesn't exist, but I
would actually consider this a bug in the GUI, not of the module.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3226>
