[GRASS-dev] [GRASS GIS] #2996: Lidar modules broken in 64bit WinGRASS
GRASS GIS trac at osgeo.org
Tue Dec 20 11:31:56 PST 2016
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  reopened
  Priority:  critical    |  Milestone:  7.0.6
 Component:  Packaging   |    Version:  svn-releasebranch70
Resolution:              |   Keywords:  lasinfo, r.in.lidar, v.in.lidar,
                         |  r3.in.lidar, libLAS
       CPU:  x86-64      |   Platform:  Unspecified
Comment (by martinl):
 Replying to [comment:19 martinl]:
 > Replying to [comment:18 annakrat]:
 > > I tested on 2 machines. First one is freshly installed Windows 10 and
 r.in.lidar does not even start. Here it seems some of the needed dlls are
 missing. When running r.in.lidar from terminal, it says msvcp120.dll and
 msvcr120.dll are missing. So I found them in some obscure system directory
 and copied them to extrabin and then everything works.
 > standalone or osgeo4w installer. If standalone did you installed
 Microsoft Runtime Libs? Ma
 I tried to install fresh Windows 8.1 and install winGRASS720svn. I can
 confirm this issue, it says msvcp120.dll and msvcr120.dll are missing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2996#comment:22>
