[GRASS-dev] [GRASS GIS] #2996: Lidar modules broken in 64bit WinGRASS
GRASS GIS trac at osgeo.org
Tue Dec 20 11:42:25 PST 2016
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  reopened
  Priority:  critical    |  Milestone:  7.0.6
 Component:  Packaging   |    Version:  svn-releasebranch70
Resolution:              |   Keywords:  lasinfo, r.in.lidar, v.in.lidar,
                         |  r3.in.lidar, libLAS
       CPU:  x86-64      |   Platform:  Unspecified
Comment (by hellik):
 Replying to [comment:22 martinl]:
 > Replying to [comment:19 martinl]:
 > > Replying to [comment:18 annakrat]:
 > > > I tested on 2 machines. First one is freshly installed Windows 10
 and r.in.lidar does not even start. Here it seems some of the needed dlls
 are missing. When running r.in.lidar from terminal, it says msvcp120.dll
 and msvcr120.dll are missing. So I found them in some obscure system
 directory and copied them to extrabin and then everything works.
 > > standalone or osgeo4w installer. If standalone did you installed
 Microsoft Runtime Libs? Ma
 > I tried to install fresh Windows 8.1 and install winGRASS720svn. I can
 confirm this issue, it says msvcp120.dll and msvcr120.dll are missing.
 AFAIK it's Visual C++ 2013 Redistributable
Ticket URL: <https://trac.osgeo.org/grass/ticket/2996#comment:23>
