[GRASS-dev] [GRASS GIS] #2996: Lidar modules broken in 64bit WinGRASS
trac at osgeo.org
Tue Dec 20 11:44:13 PST 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: critical | Milestone: 7.0.6
Component: Packaging | Version: svn-releasebranch70
Resolution: | Keywords: lasinfo, r.in.lidar, v.in.lidar,
| r3.in.lidar, libLAS
CPU: x86-64 | Platform: Unspecified
Comment (by hellik):
Replying to [comment:23 hellik]:
> Replying to [comment:22 martinl]:
> > Replying to [comment:19 martinl]:
> > > Replying to [comment:18 annakrat]:
> > > > I tested on 2 machines. First one is freshly installed Windows 10
and r.in.lidar does not even start. Here it seems some of the needed dlls
are missing. When running r.in.lidar from terminal, it says msvcp120.dll
and msvcr120.dll are missing. So I found them in some obscure system
directory and copied them to extrabin and then everything works.
> > > standalone or osgeo4w installer. If standalone did you installed
Microsoft Runtime Libs? Ma
> > I tried to install fresh Windows 8.1 and install winGRASS720svn. I can
confirm this issue, it says msvcp120.dll and msvcr120.dll are missing.
> AFAIK it's Visual C++ 2013 Redistributable
[https://www.microsoft.com/en-US/download/details.aspx?id=40784 Visual C++
Redistributable Packages for Visual Studio 2013 ]
Ticket URL: <https://trac.osgeo.org/grass/ticket/2996#comment:24>
