[GRASS-dev] r.colors.out_sld problems installing and running
Luca Delucchi
lucadeluge at gmail.com
Wed Dec 21 07:50:06 PST 2016
On 21 December 2016 at 16:37, Paulo van Breugel <p.vanbreugel at gmail.com> wrote:
> Hi Hamish
Hi all,
> I am trying to install your r.colors.out_sld plugin using g.extension, but I
> am getting the following error message:
> Compiling...
> /tmp/grass7-paulo-7909/tmpBesVaZ/r.colors.out_sld/docs/html/r.colors.out_sld.html:73:0:
> Error (IndexError('pop from empty list',)): export of contious color rules
> (ramp).</p>
> make: ***
> [/tmp/grass7-paulo-7909/tmpBesVaZ/r.colors.out_sld/docs/man/man1/r.colors.out_sld.1]
> Error 1
> ERROR: Compilation failed, sorry. Please check above error messages.
> This looks like it might be an issue with the html page, which does not seem
> to follow the guidelines. Attached a patch file
> (r.colors.out_sld_html.patch) with some changes to comply with the
> guidelines, which perhaps solves above.
> After copying the script to the script folder, the plugin runs fine for maps
> with categories, but gives an error for raster layers without categories.
> The attached patch (r.colors.out_sld.patch) corrects this I hope.
yes I got the same errors, I applied bot patches.
Thanks a lot
> Best wishes,
> Paulo
ciao
Luca
www.lucadelu.org
