[GRASS-dev] g.region -a results in a (slightly) different resolution
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Dec 23 06:54:52 PST 2016
Dear devs,
As I understand, setting the a flag when defining a region should
maintain the original resolution. So when setting different bounds based
on a vector layer and with the a flag set, I would expect exactly the
same resolution. Yet, the below output shows that this is not the case
(even though differences are small). Am I misunderstanding something?
GRASS 7.3.svn (Latlon):~ > g.region -g
projection=3
zone=0
n=10
s=0
w=-80
e=-70
nsres=0.00025
ewres=0.00025
rows=40000
cols=40000
cells=1600000000
GRASS 7.3.svn (Latlon):~ > g.region -a vector=pastures
projection=3
zone=0
n=9.26125
s=9.1445
w=-79.85875
e=-79.6625
nsres=0.000250000000000003
ewres=0.00024999999999999
rows=467
cols=785
cells=366595
