[GRASS-dev] pysal file I/O
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Fri Dec 23 14:49:46 PST 2016
Depends what you are planing to do in more detail. But maybe the pygrass Vector or VectorTopo module could be of help...
https://grass.osgeo.org/grass70/manuals/libpython/pygrass_vector.html
Cheers
Stefan
________________________________________
Von: grass-dev [grass-dev-bounces at lists.osgeo.org] im Auftrag von Paulo van Breugel [p.vanbreugel at gmail.com]
Gesendet: Freitag, 23. Dezember 2016 22:34
An: Helmut Kudrnovsky; grass-dev at lists.osgeo.org
Betreff: Re: [GRASS-dev] pysal file I/O
On 23 December 2016 3:26:58 pm Helmut Kudrnovsky <hellik at web.de> wrote:
> pvanbosgeo wrote
>> I am trying to write a script using pysal for point pattern analysis. From
>> their manual, "PySAL contains a new file input-output API that should be
>> used for all file IO operations" (
>> pysal.readthedocs.io/en/latest/users/tutorials/fileio.html).
>> Does anybody know or has suggestions how to get a grass vector layer ready
>> for further analysis with pysal within a grass script using this I/O api?
>> Paulo
>> grass-dev mailing list
>> grass-dev at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> In mentioned doc, there are e.g. Shapefile or csv listed as exchange format?
> AFAIU the I/O api is able to read these listed exchange formats.
Yes, but I was wondering if it would be possible without first converting / exporting to another format.
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/pysal-file-I-O-tp5301192p5301198.html
> Sent from the Grass - Dev mailing list archive at Nabble.com<http://Nabble.com>.
