[GRASS-dev] pysal file I/O
Helmut Kudrnovsky hellik at web.de
Sat Dec 24 06:17:49 PST 2016
>However, I
>thought perhaps there is a more direct way to write a grass vector >layer
>to pysal format that people know of. If not, I'll use the
>grass-shapefile-pysal route.
no idea if pysal is able to read from pipe, if it's about point maybe it's
possible to feed the pipe by some v.report/v.db.select/pygrass output?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/pysal-file-I-O-tp5301192p5301268.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
