[GRASS-dev] g.region -a results in a (slightly) different resolution
Markus Neteler
neteler at osgeo.org
Wed Dec 28 07:21:59 PST 2016
On Sat, Dec 24, 2016 at 10:40 AM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> So depending on
> the intended behaviour, perhaps the note should be changed to:
> "By default the region resolution is aligned to match the region boundaries.
> With the -a flag all four boundaries are adjusted to be even multiples of
> the
> resolution, aligning the region to the resolution supplied by the user
> (res=xxx), or, if not supplied, to the current resolution"
>From this text change it is not obvious to me what to remove and what to keep.
Please send a diff, thanks.
Markus
