[GRASS-dev] [GRASS GIS] #3234: d.barscale: HTMLParser.HTMLParseError: EOF in middle of construct
GRASS GIS trac at osgeo.org
Thu Dec 29 00:56:28 PST 2016
 Reporter:  spareeth   |      Owner:  grass-dev@…
     Type:  defect     |     Status:  new
 Priority:  normal     |  Milestone:  7.2.1
Component:  Compiling  |    Version:  svn-trunk
 Keywords:             |        CPU:  x86-64
 Platform:  Linux      |
 Hi
 While I am trying to compile GRASS-trunk in a system with Ubuntu 14.04.3
 LTS and is getting following errors:
 Started compilation: Wed Dec 28 17:01:10 CET 2016
     Errors in:
 /dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/display/d.barscale
 /dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/display/d.linegraph
 /dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/display/d.northarrow
     /dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/display/d.vect
     /dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/raster/r.colors
     /dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/vector/v.colors
 /dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/temporal/t.rast.colors
     /dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/man
 cd  "~/usr/local/src/grass7_trunk/display/d.barscale && make"
 give this error and same for all the other modules listed above.
     sajid.pareeth at disi-
 rsnode08:/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/display/d.barscale$
 make
     VERSION_NUMBER=7.3.svn
 /dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/dist.x86_64-pc-linux-
 gnu/tools/g.html2man.py
 gnu/docs/html/d.barscale.html
 gnu/docs/man/man1/d.barscale.1
       File
 "/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/dist.x86_64-pc-
 linux-gnu/tools/g.html2man.py", line 71, in <module>
         main()
       File
 linux-gnu/tools/g.html2man.py", line 50, in main
         p.close()
       File "/home/sajid.pareeth/usr/local/lib/python2.7/HTMLParser.py",
 line 112, in close
         self.goahead(1)
 line 164, in goahead
         self.error("EOF in middle of construct")
 line 115, in error
         raise HTMLParseError(message, self.getpos())
     HTMLParser.HTMLParseError: EOF in middle of construct, at line 54,
 column 8
     make: ***
 [/dati/homes/sajid.pareeth/usr/local/src/grass7_trunk/dist.x86_64-pc-
 linux-gnu/docs/man/man1/d.barscale.1] Error 1
 GRASS stable version compile without errors.
 Sajid
Ticket URL: <https://trac.osgeo.org/grass/ticket/3234>
