[GRASS-dev] [GRASS GIS] #2886: v.import/r.import: UnicodeEncodeError when path contains special characters
trac at osgeo.org
Mon Feb 1 08:28:38 PST 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Default | Version: svn-trunk
Keywords: v.import r.import encoding | CPU: Unspecified
Platform: Unspecified |
Trying to importing a file that resides in a path with special characters
(accent in this case), I get the following errors.
In trunk:
> v.import
input=/home/mlennert/Données/ne_110m_admin_0_countries/ne_110m_admin_0_countries.shp
output=countries
File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/scripts/v.import", line 284, in <module>
options, flags = grass.parser()
gnu/etc/python/grass/script/core.py", line 719, in parser
cmdline += [b'"' + encode(arg) + b'"' for arg in sys.argv[1:]]
gnu/etc/python/grass/script/utils.py", line 174, in encode
return string.encode(enc)
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 25:
ordinal not in range(128)
In release70:
> v.import
output=countries
File "/home/mlennert/SRC/GRASS/grass70_release/dist.x86_64-pc-linux-
gnu/scripts/v.import", line 273, in <module>
sys.exit(main())
gnu/scripts/v.import", line 158, in main
f.write('GISDBASE: %s\n' % GISDBASE)
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in
position 29: ordinal not in range(128)
I get exactly the same errors with r.import.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2886>
