[GRASS-dev] [GRASS GIS] #2886: v.import/r.import: UnicodeEncodeError when path contains special characters
trac at osgeo.org
Mon Feb 1 08:34:41 PST 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Default | Version: svn-trunk
Resolution: | Keywords: v.import r.import encoding
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [ticket:2886 mlennert]:
> Trying to importing a file that resides in a path with special
characters (accent in this case), I get the following errors.
> In trunk:
> > v.import
input=/home/mlennert/Données/ne_110m_admin_0_countries/ne_110m_admin_0_countries.shp
output=countries
> Traceback (most recent call last):
> File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/scripts/v.import", line 284, in <module>
> options, flags = grass.parser()
gnu/etc/python/grass/script/core.py", line 719, in parser
> cmdline += [b'"' + encode(arg) + b'"' for arg in sys.argv[1:]]
gnu/etc/python/grass/script/utils.py", line 174, in encode
> return string.encode(enc)
> UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 25:
ordinal not in range(128)
> In release70:
Correction: in release70 the below error is due to GISDBASE containing an
accent, not because of the file path. When GISDBASE does not contain an
accent, below import works, even if the path to the imported file contains
an accent.
> > v.import
output=countries
> File "/home/mlennert/SRC/GRASS/grass70_release/dist.x86_64-pc-linux-
gnu/scripts/v.import", line 273, in <module>
> sys.exit(main())
gnu/scripts/v.import", line 158, in main
> f.write('GISDBASE: %s\n' % GISDBASE)
> UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in
position 29: ordinal not in range(128)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2886#comment:1>
