[GRASS-dev] [GRASS GIS] #2887: GUI startup: encoding error if location with accent has been renamed to other name
trac at osgeo.org
Mon Feb 1 08:42:26 PST 2016
other name
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Startup | Version: svn-trunk
Keywords: encoding | CPU: Unspecified
Platform: Unspecified |
* Start GRASS with GISDBASE=/home/mlennert/DonnéesGRASS
* Leave GRASS
* Rename /home/mlennert/DonnéesGRASS to /home/mlennert/DonneesGRASS
* Start GRASS without indicating a location
I get:
grass71
Nettoyage des fichiers temporaires ...
access: No such file or directory
ERREUR :LOCATION </home/mlennert/DonnéesGRASS/ETRS_4258> not available
Démarrage du SIG GRASS ...
(gis_set.py:18310): Gtk-WARNING **: Unable to locate theme engine in
module_path: "adwaita",
File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/gui/wxpython/gis_set.py", line 1115, in <module>
GRASSStartUp = StartUp(0)
File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk2/wx/_core.py", line
8628, in __init__
self._BootstrapApp()
8196, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
gnu/gui/wxpython/gis_set.py", line 1091, in OnInit
StartUp = GRASSStartup()
gnu/gui/wxpython/gis_set.py", line 214, in __init__
self._set_properties(grassVersion, grassRevisionStr)
gnu/gui/wxpython/gis_set.py", line 266, in _set_properties
self.OnSetDatabase(None)
gnu/gui/wxpython/gis_set.py", line 867, in OnSetDatabase
self._showError(_("Path '%s' doesn't exist.") % gisdbase)
gnu/gui/wxpython/gis_set.py", line 487, in _showError
self.lmessage.SetLabel(_("Error: {text}").format(text=text))
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in
position 25: ordinal not in range(128)
In trunk and in release70.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2887>
