[GRASS-dev] [GRASS GIS] #2888: r.external wizzard shows "projection mach: no" although location was created by one of the dataset
trac at osgeo.org
Mon Feb 1 10:24:34 PST 2016
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Raster | Version: unspecified
Keywords: r.external | CPU: x86-64
Platform: MSWindows 7 |
tested with
System Info
GRASS version: 7.1.svn
GRASS SVN revision: 67699
Build date: 2016-01-29
Build platform: x86_64-w64-mingw32
GDAL: 1.11.3
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
dataset is Landsat 8 scene
gdalinfo LC81920282015221LGN00_B1.TIF
Driver: GTiff/GeoTIFF
Files: LC81920282015221LGN00_B1.TIF
Size is 7651, 7771
Coordinate System is:
PROJCS["WGS 84 / UTM zone 32N",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",9],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","32632"]]
Origin = (623985.000000000000000,5217915.000000000000000)
Pixel Size = (30.000000000000000,-30.000000000000000)
Metadata:
AREA_OR_POINT=Point
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 623985.000, 5217915.000) ( 10d38' 2.38"E, 47d 6'11.11"N)
Lower Left ( 623985.000, 4984785.000) ( 10d34'23.75"E, 45d 0'20.44"N)
Upper Right ( 853515.000, 5217915.000) ( 13d39' 7.40"E, 47d 1'12.57"N)
Lower Right ( 853515.000, 4984785.000) ( 13d28'47.22"E, 44d55'42.83"N)
Center ( 738750.000, 5101350.000) ( 12d 5' 5.02"E, 46d 1'26.68"N)
Band 1 Block=7651x1 Type=UInt16, ColorInterp=Gray
g.proj -p
-PROJ_INFO-------------------------------------------------
name : Universal Transverse Mercator
proj : utm
datum : wgs84
ellps : wgs84
zone : 32
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
location was created with location by ''read projection and datum terms
from a georeferenced file''.
it works in 7.0.3.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2888>
