[GRASS-dev] [GRASS GIS] #2893: Specify crs when exporting to GeoJSON
trac at osgeo.org
Wed Feb 3 04:49:21 PST 2016
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Resolution: | Keywords: v.out.ogr
CPU: Unspecified | Platform: Unspecified
Comment (by pmav99):
Hmm... it seems `ogr2ogr`'s implicit choices can lead to bugs :
If we erase the CRS field from `3857.json`:
$ cat 3857.json
"type": "FeatureCollection",
"features": [
{ "type": "Feature", "properties": { }, "geometry": { "type": "Polygon",
"coordinates": [ [ [ -9386772.821532785892487, 4162454.812297557480633 ],
[ -9383256.718231666833162, 4193793.993894479703158 ], [
-9377600.378138564527035, 4198533.089648159220815 ], [
-9386772.821532785892487, 4162454.812297557480633 ] ] ] } }
Then `ogrinfo` assumes that EPSG is 4326:
$ ogrinfo -so -al 3857.json
ERROR 4: GeoJSON Driver doesn't support update.
Had to open data source read-only.
INFO: Open of `3857.json'
using driver `GeoJSON' successful.
Layer name: OGRGeoJSON
Geometry: Polygon
Feature Count: 1
Extent: (-9386772.821533, 4162454.812298) - (-9377600.378139,
4198533.089648)
Layer SRS WKT:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]]
reprojecting does not make any changes to the coords (which is reasonable
I guess):
$ ogr2ogr -f GeoJSON -t_srs "EPSG:4326" 4326_implicit.json 3857.json
$ cat 4326_implicit.json
"crs": { "type": "name", "properties": { "name":
"urn:ogc:def:crs:OGC:1.3:CRS84" } },
"features": [
"coordinates": [ [ [ -9386772.821532784029841, 4162454.812297557014972 ],
-9377600.378138564527035, 4198533.089648158289492 ], [
-9386772.821532784029841, 4162454.812297557014972 ] ] ] } }
but this particular `(coords, crs)` combination is obviously garbage:
$ ogr2ogr -f GeoJSON -t_srs "EPSG:3857" 3857_implicit.json
4326_implicit.json
Failed to reproject feature 0 (geometry probably out of source or
destination SRS).
ERROR 1: Terminating translation prematurely after failed
translation of layer OGRGeoJSON (use -skipfailures to skip errors)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2893#comment:1>
