[GRASS-dev] [GRASS GIS] #2893: Specify crs when exporting to GeoJSON
trac at osgeo.org
Wed Feb 3 04:56:11 PST 2016
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Resolution: | Keywords: v.out.ogr
CPU: Unspecified | Platform: Unspecified
Comment (by rouault):
Quoting the geojson spec ( http://geojson.org/geojson-spec.html
#coordinate-reference-system-objects ) : "The default CRS is a geographic
coordinate reference system, using the WGS84 datum, and with longitude and
latitude units of decimal degrees." . So OGR behaviour follows the spec.
And the new geojson spec ( https://www.ietf.org/id/draft-ietf-
geojson-00.txt ) deprecates the use of other CRS : "Other coordinate
reference systems, including ones described by CRS objects of the kind
defined in [GJ2008] are NOT RECOMMENDED"
Ticket URL: <http://trac.osgeo.org/grass/ticket/2893#comment:2>
