[GRASS-dev] [GRASS GIS] #2892: t.rast.aggregate: error when input space time raster dataset store many rasters
trac at osgeo.org
Wed Feb 3 06:19:40 PST 2016
rasters
Reporter: tmsz | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Temporal | Version: 7.0.2
Resolution: | Keywords: wingrass, t.rast.aggregate, g.message
CPU: x86-64 | Platform: MSWindows 7
Comment (by veroandreo):
I followed your workflow but I wasn't able to reproduce the error you get.
I'm using grass71 (r67703) under Fedora 23. Have you tried with the new
grass gis stable version 7.0.3?
Btw, your offsets in r.in.gdal didn't work for me, they left one map out
and then it was not possible to register maps. So, here is how I changed
them (and the total count is now 23922):
r.in.gdal -oe input=tg_0.25deg_reg_1950-1964_v12.0.nc
output=temperature_mean offset=0
r.in.gdal -oe input=tg_0.25deg_reg_1965-1979_v12.0.nc
output=temperature_mean offset=5479 --o
r.in.gdal -oe input=tg_0.25deg_reg_1980-1994_v12.0.nc
output=temperature_mean offset=10957 --o
r.in.gdal -oe input=tg_0.25deg_reg_1995-2015_v12.0.nc
output=temperature_mean offset=16436 --o
For the rest, the monthly aggregation works just fine here and no error
regarding filename or extension. Have you tried shrinking names? Something
like: basename=month_tmean?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2892#comment:1>
