[GRASS-dev] [GRASS GIS] #2892: t.rast.aggregate: error when input space time raster dataset store many rasters
trac at osgeo.org
Wed Feb 3 08:33:08 PST 2016
rasters
Reporter: tmsz | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Temporal | Version: 7.0.2
Resolution: | Keywords: wingrass, t.rast.aggregate, g.message
CPU: x86-64 | Platform: MSWindows 7
Comment (by tmsz):
This error appear on OS Windows platform only. Offset for import rasters
can be different on OS GNU/Linux. I think problem is not with raster name
length.[[BR]]
When I run t.rast.aggregate, which inner create process (in the source
code for create new process is called python method
_subprocess.CreateProcess() on OS Windows platform) with argument which is
command-line calling g.message command with argument message which is very
long. On Windows OS platform is command-line string limitation for total
length of the following command line (last previous link).
#!div style="font-size: 100%"
short preview, how is g.message called on OS Windows:
"C:\Program Files (x86)\GRASS GIS 7.0.2\bin\g.message.EXE" -i
"message=granularity_list:
[<grass.temporal.space_time_datasets.RasterDataset object at 0x040968F0>,
Check the text file (complete g.message command calling) in the attached
previous archive.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2892#comment:2>
