[GRASS-dev] [GRASS GIS] #2919: r.stream.extract error
GRASS GIS trac at osgeo.org
Mon Feb 15 07:49:10 PST 2016
 Reporter:  PitStop           |      Owner:  grass-dev@…
     Type:  defect            |     Status:  new
 Priority:  normal            |  Milestone:
Component:  Addons            |    Version:  7.0.3
 Keywords:  r.stream.extract  |        CPU:  x86-64
 Platform:  MSWindows 7       |
 Hi There,
 I'm trying to delineate a watershed and also extract the streams within
 using here for reproduction the NC data set.
 r.watershed elevation=elev_srtm_30m at PERMANENT threshold=1000
 accumulation=accu drainage=drain basin=basin
 and then
 r.stream.extract elevation=elev_srtm_30m at PERMANENT accumulation=accu at user1
 threshold=1000 stream_raster=stream_r stream_vector=stream_v
 leads to
 ERROR: Missing value for parameter <d8cut>
 while the accumulation map is specified in the command and therefor d8cut
 shouldn't be used.
 The same error was report [http://osgeo-org.1560.x6.nabble.com/r-stream-
 extract-grass7-addon-td5018389.html#a5018528]
 g.version -g
 version=7.0.3
 date=2016
 revision=67691
 build_date=2016-01-28
 build_platform=x86_64-w64-mingw32
Ticket URL: <https://trac.osgeo.org/grass/ticket/2919>
