[GRASS-dev] [GRASS GIS] #2918: Infinite loop in i.landsat.toar with method=DOS4
trac at osgeo.org
Thu Feb 18 07:38:14 PST 2016
Reporter: DmitryKolesov | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Imagery | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: All
Comment (by mlennert):
Replying to [ticket:2918 DmitryKolesov]:
> == Description: ==
> I.landsat.toar with method=DOS4 fails to stop. For example if run the
module using Landsat8 scene (id=LC81680222013351LGN00) as input, the
module doesn't finish the calculation.
Thank you for the very detailed description and the nice catch !
> == Proposed solution: ==
> I see two possibilities if Tz becomes NaN:
> * emit fatal-error like "DOS4 method isn't applicable for the scene.
Use other method or use other sun_elevation parameter." and exit.
> * emit warning, then reset Tz and Tv, using default values (1.0) for
the coefficients
(http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_0/imagery/i.landsat.toar/landsat.c#L122).
I'm no expert in the different DOS versions, but DOS4 is defined as:
DOS4: TAUv = exp[-t/cos(sat_zenith)], TAUz = exp[-t/sin(e)], Esky = PI *
radiance_dark
Does this really make sens when TAUv and TAUz are set to 1 ?
Unless it does, I would prefer your first solution.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2918#comment:1>
