[GRASS-dev] [GRASS GIS] #2916: configure bug (?): FORTIFY_SOURCE in CPPFLAGS breaks configure on Arch Linux
trac at osgeo.org
Mon Feb 15 15:32:59 PST 2016
Linux
Reporter: msieczka | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Compiling | Version: 7.0.3
Resolution: | Keywords:
CPU: All | Platform: Linux
Comment (by neteler):
Replying to [ticket:2916 msieczka]:
> gcc 5.3.0, make 4.1, autoconf 2.69
You would need to use autoconf-2.13 if you want to regenerate the
configure script. But I guess you don't do that anyway.
I tried on my Fedora box:
Copying config.status to config.status.x86_64-pc-linux-gnu
GRASS is now configured for: x86_64-pc-linux-gnu
Source directory: /home/neteler/software/grass71
Build directory: /home/neteler/software/grass71
Installation directory: ${prefix}/grass-7.1.svn
C compiler: gcc -O2 -march=native -fdiagnostics-color
C++ compiler: c++ -O2 -D_FORTIFY_SOURCE=2
gcc --version
gcc (GCC) 5.3.1 20151207 (Red Hat 5.3.1-2)
I have a link which seems to be missing on your system according to your
log file:
ls -la /lib/cpp
lrwxrwxrwx 1 root root 10 Dec 8 18:45 /lib/cpp -> ../bin/cpp*
# its origin:
rpm -qf /lib/cpp
cpp-5.3.1-2.fc23.x86_64
Maybe you simply lost that link?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:2>
