[GRASS-dev] [GRASS GIS] #2916: configure bug (?): FORTIFY_SOURCE in CPPFLAGS breaks configure on Arch Linux
trac at osgeo.org
Tue Feb 16 03:21:23 PST 2016
Linux
Reporter: msieczka | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Compiling | Version: 7.0.3
Resolution: | Keywords:
CPU: All | Platform: Linux
Comment (by msieczka):
Replying to [comment:2 neteler]:
> Replying to [ticket:2916 msieczka]:
> > gcc 5.3.0, make 4.1, autoconf 2.69
> You would need to use autoconf-2.13 if you want to regenerate the
configure script. But I guess you don't do that anyway.
I'd rather rely on an upstream-provided configure script, if possible.
> I tried on my Fedora box:
> C++ compiler: c++ -O2 -D_FORTIFY_SOURCE=2
Is it OK that CPPFLAGS content ends up in CXXFLAGS?
> I have a link which seems to be missing on your system according to your
log file:
> ls -la /lib/cpp
> lrwxrwxrwx 1 root root 10 Dec 8 18:45 /lib/cpp -> ../bin/cpp*
> # its origin:
> rpm -qf /lib/cpp
> cpp-5.3.1-2.fc23.x86_64
> Maybe you simply lost that link?
There is no CPP package as such on Arch Linux. cpp, gcc and g++
executables come in a single GCC package here. It doesn't provide this
`/lib/cpp' link.
Anyway, I created /lib/cpp -> ../bin/cpp symlink manually, but this
doesn't help and doesn't seem to be the actual issue. The references to a
missing /lib/cpp link only got replaced by yet more "_FORTIFY_SOURCE
requires compiling with optimization" warnings. The original errors
remain:
/usr/include/sys/cdefs.h:30:3: error: #error "You need a ISO C conforming
compiler to use the glibc headers"
gcc: error: unrecognized command line option '-nologo'
I'm attaching a complete config.log-fail-with_cpp_symlink.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2916#comment:3>
