[GRASS-dev] GRASS and vagrant
Rainer M Krug
Rainer at krugs.de
Tue Feb 16 03:38:57 PST 2016
Martin Landa <landa.martin at gmail.com> writes:
> Hi,
> recently I have added Vagrantfile [1] to trunk which enables you
> easily create a new virtual machine using vagrant, and compile/install
> GRASS on that machine. Detailed description is available on wiki [2].
> Enjoy! Martin
Thanks - this sounds very interesting. If my googling gave the right
answers, one can use Vagrant together with docker, which would make the
resulting instance much more lightweight than a full blown VM (e.g
Virtual Box).
Has anyone tried this?
Rainer
> [1] https://trac.osgeo.org/grass/browser/grass/trunk/Vagrantfile
> [2] https://grasswiki.osgeo.org/wiki/Vagrant
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160216/70dd6280/attachment.sig>
