[GRASS-dev] GRASS and vagrant
Jachym Cepicky jachym.cepicky at gmail.com
Tue Feb 16 10:49:40 PST 2016
Rainer,
afaik it does not make sense to combine vagrant and docker - there are here
for different use cases
http://stackoverflow.com/questions/16647069/should-i-use-vagrant-or-docker-for-creating-an-isolated-environment
@martin good work btw
J
Ășt 16. 2. 2016 v 12:39 odesĂ­latel Rainer M Krug <Rainer at krugs.de> napsal:
> Martin Landa <landa.martin at gmail.com> writes:
> > Hi,
> > recently I have added Vagrantfile [1] to trunk which enables you
> > easily create a new virtual machine using vagrant, and compile/install
> > GRASS on that machine. Detailed description is available on wiki [2].
> > Enjoy! Martin
> Thanks - this sounds very interesting. If my googling gave the right
> answers, one can use Vagrant together with docker, which would make the
> resulting instance much more lightweight than a full blown VM (e.g
> Virtual Box).
> Has anyone tried this?
> Rainer
> > [1] https://trac.osgeo.org/grass/browser/grass/trunk/Vagrantfile
> > [2] https://grasswiki.osgeo.org/wiki/Vagrant
> Rainer M. Krug
> email: Rainer<at>krugs<dot>de
> PGP: 0x0F52F982
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160216/170cd9da/attachment.html>
