[GRASS-dev] grass addons metadata temporary not available
    Blumentrath, Stefan
    Stefan.Blumentrath at nina.no
    Wed Feb 17 06:40:42 PST 2016
Hi Martin,
Thanks for your reply. I shall try that.
I just reinstalled GRASS 7.1, but maybe I have to reinstall from a clean source and remove the existing GRASS settings / addons.
I shall report back...
Cheers
Stefan
-----Original Message-----
From: Martin Landa [mailto:landa.martin at gmail.com]
Sent: 17. februar 2016 13:39
To: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>; Matej Krejci <matejkrejci at gmail.com>
Cc: GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] grass addons metadata temporary not available
2016-02-17 13:33 GMT+01:00 Martin Landa <landa.martin at gmail.com>:
>> Do you by chance have any idea what the reason might be that it does not work for me?
>> See:
>> http://osgeo-org.1560.x6.nabble.com/problem-installing-wx-metadata-fr
>> om-g-extension-tp5244519p5249845.html
>> Or how I might solve the issue if it is only local...
what is exact problem do you have? I installed wx.metadata
g.extension wx.metadata
and run
g.gui.metadata
the GUI dialog pops up without any error. Do you have fresh installation? Probably clean up your .grass7/addons before installing.
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
