[GRASS-dev] testsuite problems (t.connect)
Vaclav Petras
wenzeslaus at gmail.com
Thu Feb 18 06:44:01 PST 2016
On Thu, Feb 18, 2016 at 5:45 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> I think this annoing problem (to use again GRASS I have to exit and
> start GRASS) appear because in the setUpClass function a new mapset is
> created and used but in tearDownClass function the old mapset isn't
> set back and the new mapset is removed.
> I tried to fix this problem but I'm not able to store the old mapset
> somewhere and use it in the tearDownClass (self doesn't work because
> @classmethod decorator). Do you have any idea to solve this?
The classmethods don't have self but they have cls. These are the variables
you can set in the body of the class, e.g. mapsets_to_remove in the
test_distr_tgis_db_raster3d.py test [1]. You can assign the value in the
setUpClass method and use it in tearDownClass through the cls reference,
e.g. cls.mapsets_to_remove.append(mapset_name).
[1]
https://trac.osgeo.org/grass/browser/grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py?rev=67878#L19
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160218/d547e028/attachment-0001.html>
