[GRASS-dev] [GRASS GIS] #2913: i.segment.hierarchical: why is there a mandatory output option
trac at osgeo.org
Fri Feb 19 04:20:25 PST 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Addons | Version: unspecified
Resolution: | Keywords: i.segment.hierarchical output
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:1 zarch]:
> Replying to [ticket:2913 mlennert]:
> > i.segment.hierarchical has the following parameters (among others):
> > output Name of output segment raster map
> > outputs_prefix Name for output raster maps from segment
> > par défaut: seg__%.2f
> > I don't really understand the sens of 'output': The whole idea of the
module is to create multiple output maps containing the results of
hierarchical segmentation. So why would one need one single output map
name ?
> Actually I wrote this module to have a single segmented output map! :-)
Oh, I guess I was fooled by the name. 'hierarchical' evokes several maps
for me...
> The idea of the module was to parallelize the i.segment module into
cores and nodes in a cluster on single tiles, once the segmentation per
tile is done then patch the tiles in a unique map and apply i.segment
using the segmented map as seed to obtain as output a large segmented map.
Well, it is also very nice to create a series of hierarchically segmented
maps, even without using the parallel processing mode (which actually
fails for me - see #2902).
> I put also the option outputs_prefix, that probably should be change in
"basename" to define the name of the "temporary" segmented tiles.
But if you only create one output map, why go through a whole list of
thresholds for segmentation ?
In my use case, 'output' is not necessary, 'basename' is. So, at least
they should each be optional. BTW, concering this basename, see also
#2914. And while you're at it, could you also give your opinion on #2915 ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2913#comment:2>
