[GRASS-dev] [GRASS GIS] #2913: i.segment.hierarchical: why is there a mandatory output option
trac at osgeo.org
Fri Feb 19 07:55:30 PST 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Addons | Version: unspecified
Resolution: | Keywords: i.segment.hierarchical output
CPU: Unspecified | Platform: Unspecified
Comment (by zarch):
Replying to [comment:2 mlennert]:
> Replying to [comment:1 zarch]:
> > Replying to [ticket:2913 mlennert]:
> > I put also the option outputs_prefix, that probably should be change
in "basename" to define the name of the "temporary" segmented tiles.
> But if you only create one output map, why go through a whole list of
thresholds for segmentation ?
I've used to identify the "best" segment threshold
> In my use case, 'output' is not necessary, 'basename' is. So, at least
they should each be optional.
Yes, indeed they should be both optionals.
> BTW, concering this basename, see also #2914. And while you're at it,
could you also give your opinion on #2915 ?
Actually I did this morning but I realize that my replies were losts,
let's do it again.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2913#comment:3>
